rebuilding a homebuilt sedan
The pitman arm took about an hour to layout and make. So it wasn't to bad.
The steering box is a reversed corvair box.
And my shoes are leather they work well as long as I don't drop frames on them lol
here are some more pics of working on the dash, and more on the steering
got some more work done on the steering. pretty much got it all buttoned up for the most part. made new column mounts, bored a brass bushing, and cut a groove in the bushing for a snap ring to hold it in place. so nothing to spectacular.
support bushing bracket
in place
one of the steering shaft mounts
replaced the connecting rod with another bracket for the front column mount
will take some better pics tomorrow of the whole set up. forgot to so it today
Looks great - I like the way you've built the universal into the steering column. What did you use for the sleeve? I would imagine that there is a bearing in the top right close to the steering wheel? With the two supports quite close together inside the dash area, is it pretty sturdy? My roof is pretty low, and I think I'll be relying on the steering wheel getting in and out, hence my concern with it being sturdy.
The car is looking great by the way!
Thanks for all your posts and great ideas....
Bill the steering universal is not built into the column. It is a bolt on the works with a double d shaft. The column itself is a shorty speedway column that I shortened. It has a bearing at the top and bottom. The main reason I put two mounts was for the very reason you stated. With one mount you could not get the column to budge other than flex. So I wanted to put another to help with stress over time. They are about 6 inches apart and hold everything well. I plan on keeping an eye on it and if the tube starts to bend I will replace it with thicker wall tube and bore the ends for the bearings
Thanks for the answers to all my questions....now if I may ask one more? Are you putting any sort of insulators or anything between the floor structure and the frame? I'm in exactly the same place with my build.....any advice? I figured I'd need something to minimize noise, vibration, etc, but it would sure be a lot easier if I didn't have to!
Thanks in advance....
yea the body will be rubber mounted. the way i do it is build the skeleton then made the mounts, cut out some rubber pucks out of some .750 rubber sheet i have and raise the body some ( roughly .250 in) with the rubber. the mounts are on the side of the rails set .50 inches from the top to achieve the .250 clearance
I like them both! Nice down sweep angle on the header. makes it look fast sitting there
finished up the headers. also the owner wanted a skid plate made to protect the aluminum oil pan, ask and you shall receive
nice tight fitment of the tubes to the cones, before i cut out the holes and fully welded. some pics of some of the welds
skid plate fabbed up
some welding on the skid plate
here are some pics of the skid plate tacked in. need some opinions on the fin on the header, not sure how i feel about it.
also snapped a shot of the model a's lined up
a small update, doing some little things for the Cincinnati world of wheels. finished up the floor skeleton, started mounting the seats to the skeleton (floor will still be fully skinned), and mounted some carbs and a scoop. some pics............
what i started with today
bending up the last pieces of the floor skeleton
skeleton going in
seat risers
seats bolted up
