Scratch Building a Coupe
Photos.. Roof frame work 1 inch sqaure tube with 3/4 inch tubing inside for support after welding back together. I miss calculated on the length of the tubing when I bent the ends. Its easier to cut them in half and weld them back together with the splicer shown perfect fits.
Photos..Roof top frame work
photos.. Roof top
Photos.. Raising the roof as they say
rsfyj rsfyj is online now
Default Scratch Building a Coupe
I started in September of 2011, implementing my ideas to build a Coupe of sorts from scratch. I started with some simple plans found on line using 20 feet of 1.5x3 rectangular tubing. I built it in 6 hrs for $49 bucks worth of steel. The bad news is My computer went south along with all my photos of the frame and the 1975 Mustang 2 that I wrestled out the front suspension and rear axle, as well as other pieces I could use down the road. However I fixed the Computer and now keep a CD of all my photos. It is now December 2011 and I have a rolling chassis with Engine and drive train. I plan on posting photos as I go when I find out how to post them here, It will take some time to rummage through all the photos to find the right ones in sequence to fit this on going story. My overall plan is to build the complete Coupe all from scratch all the framing members and the sheet metal etc. I will try to keep this build going in order that I preformed all the parts. This will be , by the way, a low cost operation as I have always done things. You wont see any chrome, or fancy car parts that I can do without. I cry each night that I have to buy the steel as I can't make that. Okay Ive set the stage that I am a cheap feller. Now I will look for some early photos and figure out how to post them...
Reply With Quote Multi-Quote This Message Quick reply to this message
#2 Report Post
Old 12-14-2011, 12:27 AM This is the thread that belongs with this group of Posts
Photos, Showing the angles I put on the roof line. I used a piece of 1 inch black pipe i retrieved from the dump in the front sloping part of the roof.
Photos. More roof angle structures
Photos, More roof angle frame work
Photos.. I think the end of these roof angle photos.
Photos.. Starting some of the metal on the cab corners from a old water tank that was in my home.
Photos.. More Cab corner metal etc
Photos.. Photos are starting to get near the current work i am doing now...
Photos.. We are sneaking up on what I am currently doing to the Rod
Photos This water tank metal is 18 gauge good stuff hope I can get some more free stuff. This tank costs $300 bucks or more to replace in my home. Now I get some payback.
Photos..Free metal but I try to use every last piece as you will see where I put in small pieces to finish. When its all ground down it will all look the same. I love this free stuff...
Photos.. Starting sheet metal on top corner
