The Puzzle replacement
Spent the better part of 2 days needle descaleing the trunk and got it in etching primer. Next the inside floor.
worked my way up front today, well the first half anyway.
I finally made my mind up on what to do about tail lights and filled the holes the that someone had put in it where the stock one where.
I formed some tin and filled the holes,
Tail light holes done and the gas door is gone. progress is being made.
Today I took all the front end off and got it way up in the air. Time to install the new power rack-n-pinion steering, hope it works:confused:
Its been alota work but I finally have a rack mount made and ready to install.
Now to get the steering shaft correct. It looks like 2 u-joints will do it fine.
Man that is looking good. I've always liked those year Chevys with the tail filled and the tail lights incorporated into the bumper. :cool:
You know I was a huge fan of the "Puzzle" and hated to see you sell it but I believe this car is just what you needed. You are going at it with a passion and I'm loving it! [cl[cl
[P[P[P
I like what you did on the stock tail lights, it gives it a real custom touch......What are your plans for the tail lights?
As of right now they are going in a set of Caddy bumper guards, we will see how that all works out. Sometimes I might bite off a bit more than I can chew.:rolleyes:
[P[P[P
Thanks, I did alot of work on the Puzzle and I hate give'n up on things but my heart just wasn't into it at the end there and I really am a full bodied sled kinda guy anyway so yes this is way more my style. With any luck and some bucks I will be driving it this summer.
Got one lower controll arm dropped 2"s today. So along with the 2" drop spindle and 2.5 coils out of the springs I should be down about 4to 5 inch's I hope.:confused: Almost have the rack n pinion steering done also.
Not real sure if anyone is seeing any of this but here is some more progress.
I got the rack mount built and in and now have pwr/rack and pwr disk brakes up front. I also did a 2" drop on the lower controll arms.
Started the tail lights today also, and now I see way to much multi tasking going on:rolleyes:
Got the lower hole cut today in the bumper guard and now I am not sure I like it at all. But it apears I am stuck with it like it or not.
Remember these are just roughed in:eek: I want this one done before I destroy the other guard that is almost perfect.:rolleyes:
