steering is only as good as parts used. example: I'm not using the orginal tie rod ends - off 31 Ply. ford are even sloppier, using tie rod ends off B body MoPar (new). Rack don't look right on older style rods, maybe ok for a full fendered car with a mustang II /nove front end. no play in them if done right with new tie rod ends. What are you building? My 66 Charger with a built 383/ 4 speed 4:10 rear gears has the same gear box I'm using in my 31 Plymouth coupe. Don't know if I answered you question or not- I ramble alot![cl
