klink
I need to put a shallow bend (sweeping radius) in 6X2X1/8 rectangular tubing. The depth of the bend needs to be about 1 inch over a 52 inch length. Seems easy enough... The length of the material is 12', but the sweep needs to be towards one end. The end result will be frame rails for my 30' Chevy. I'm trying to follow the contour of the floor pan from the firewall back to the rear wheel openings. The car will be fenderless and the frame will be in a bit from the sill. It'll be flush at the firewall and rear wheel well openings. The rear wheel wells are about 1 inch in from the outside contour of the body at the floor.
The backup plan calls for slicing the tubing to allow movement for a nice subtle controlled bend, then welding the slices back up. I'll be using this method to "straighten" the rails for the forward section of the frame. The idea I'm chewing on is setting up two work knees 52" apart, lightly clamping the tubing to the knees so they can slide, and pushing the tubing with a hydraulic ram. My concern with this method is that I'll end up with more of a "V" shape than a sweep.
Any suggestions would be welcomed.
Thanks...
Thanks...
