Bonehead
Use a log chain and a hydraulic jack. Set the jack where you want the deepest part of the bend. Hook the chain in one end, and run the chain over the jack and hook the other end. Use a boomer to take up the slack in the chain. Then jack the jack until you get the tube bent. Remember there will be some spring back, and be very carefull when the jack has tension on it, so the chain does not slip off the top of the jack. It will take some patience to get them both the same, but it can be done.
I managed to bend a piece of 2X4X1/8 using my floor jack. I chained both ends to my welding table, placed the floor jack under it and applied some force. The 2X4 bent nicely. Then I mounted up the 2X6 and it blew the seals. I re-built the jack and paired it up with a bottle jack (small one like you'd keep in the vehicle) and nothing. The 2X4 required about 2 inches of "over" bend to get what I want. The 2X6 moved about 4 inches and went right back. [cl
The chain method works, I use a big jack, 20 ton. But a few small cuts and that thing will bend great.
