Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Fuel systems Q&A
Fuel systems Q&A Carbs, injection, tanks, lines, pumps, everything fuel system related!
Old 11-16-2018, 05:48 PM
skull's Avatar
skull skull is offline
''SARCASM: just one of his many talents.''
Lightbulb predator carb--thoughts
got a chance to get a predator carb 5OOO series, thinking about sticking it on the 454 "THAT" has in it,
Later
my opinion only, valid where prohibited, for official abuse only.
1928 maxwell hybrid build/drag car
http://ratrodsrule.com/forum/showthread.php?t=37455
1948 dodge truck in deceased son's memory.
http://www.ratrodsrule.com/forum/sho...odge+truck+son
1930 2dr mopar.
http://ratrodsrule.com/forum/showthr...ht=30+mopar+dr
Old 11-16-2018, 07:08 PM
smallfoot's Avatar
smallfoot smallfoot is offline
I've looked at them although never used one. Most of the reviews I've seen are positive. I liked the simplicity. They don't come up on sites around here like CL very often so that may be a good sign people don't get rid of them once they tried them. They are pretty pricey new. Didn't see much from everyday users but mostly racers..keeping my mind open about them. If you try it, let us know.
Old 11-16-2018, 07:25 PM
I've been intrigued by Predator carbs since I first saw them in the '80's.
Like any carburetor design, understanding how it works and how to tune it is the difference between satisfaction and bitter disappointment!
A few years ago, I did some research on the subject. I'm not sure if I have that stuff on file anymore... I'll do some digging and get back to you...
Old 11-16-2018, 07:31 PM
Toad's Avatar
Toad Toad is offline
I heard they do well in racing situations but not that well for the streets! They also have a richer fuel mix that can be costly on a daily!
Toad
Why did the toad cross the road?
Old 11-16-2018, 09:04 PM
skull's Avatar
Default thanks
[ Toad; ]I heard they do well in racing situations but not that well for the streets! They also have a richer fuel mix that can be costly on a daily! [
if it don't work for the rat, guess l can always throw it on the dart drag car, either way it is to cheap to pass up,
always good feed back on the forum
Later
1930 2dr mopar.
Old 11-16-2018, 09:29 PM
Bought one new when they first came out.
Not worth a hoot for street use unless you get the one with the idle circuit built in.
Old 11-17-2018, 12:33 PM
ssimpala ssimpala is offline
The 6000 series was pretty decent...the 5000 not so much. Can you even still get a gasket kit for them?
Old 11-17-2018, 01:56 PM
There were two street cars around here with Predator carbs. A Luv with a sbc and one carb and a Willys sedan with two of them on a cross ram. I talked to both owners about the carbs. Both had the idle circuit add-on. The Luv was satisfied and the Willys was working out bugs. Last time I saw the cars they both had removed the Preds.
Never seen one at the strip but I'm not out there all that much.
Old 11-18-2018, 12:04 PM
First class!!!!!!!!!!!!!
Old 11-25-2018, 07:25 PM
bgbrktracer's Avatar
bgbrktracer bgbrktracer is offline
They were used a lot on drag cars and drag boats down here. Haven't seen one in years.
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
