Well, somehow I screwed up my measurements and had to spin the mounting bracket far enough forward to get the tie rod to clear the crank pulley. But, it turned out to be a blessing in disguise. I figured out how to get the lower 4 bars to adjust. The plan is, still a 1" hole dead center into a piece of pipe, then insert a weld bung, and finally use a 4 bar end. Should give me the adjustability that I need. Also mounted my rear air bags, well sort of. they're tacked into place ready to be welded in fully. I'll get some pictures up tomorrow.
