gears and stuff
when we finished the car it ended up with these specs:
Weight:
24OO pounds with full tank of fuel:
Rearend:
9 inch ford with 3:25 gears
Trans:
7OOR4 rebuilt by my friend to stand up to 5OOHP and wicked 1 - 2 shift, it will snap your'e head back at half throttle when it shifts.
Chevy Small-Block V-8 rebuilt:
Based on the ZZ4 platform
355 HP/405 FT.LB
Displacement: 355 CI
Bore x Stroke (in.): 4.030 x 3.480
Block : Cast-iron with four-bolt main caps
Crankshaft: Forged steel
Connecting Rods: Powdered metal steel
Pistons: High-silicon aluminum with offset pins
Compression ratio: 10:1
Camshaft Type: Steel hydraulic roller
Camshaft Lift (in.): .474 intake / .510 exhaust
Camshaft Duration (@.050 in.): 208° intake / 221° exhaust
Intake: Aluminum no name dual plane with power range off idle to 55OO RPM
Distributor: Hi output HEI billet aluminum after market
Spark plugs: Acell
Spark Plug Wires: Acell make it yourself kit
Water pump: Hi-flow aluminum
Headers: custom made free flowing roadster into 3 inch exhaust
Mufflers: 3 inch low back pressure baffle
Radiator:
Up/down flow 3 core custom made aluminum
Heads:
Cast iron 58-cc chamber
Valve Size (in.): 1.940 intake / 1.500 exhaust
Rocker Arms: full aluminum rollers
Rocker Arm Ratio: 1.5:1
Recommended Fuel: 92 octane
Ignition Timing: Base 10° BTDC, 32° Total
Maximum Recommended rpm: 5800
Balanced: External
Edelbrock carb:
600 CFM, ELECTRIC CHOKE
(CALIBRATED FOR FUEL ECONOMY)
Calibrated for maximum fuel economy. Includes timed vacuum ports, EGR and fuel vapor outlet. Not for computer-controlled engines. with the following jets, rods and springs: Metering Jets - Primary .098, Secondary .095; Metering Rods - .073 x .047; Step-Up Spring - orange (5" Hg).
Tire size in the rear:
BF Goodrich P285-7O-15
3O.7 inches tall X 11.5 wide
l think that should answer the question,
Later
