1933 Pontiac
I had a chance to build the engine mounts today [;)
attachment.php
attachment.php
Tomorrow the tranny mount.
I contacted the engine builder today and I'm gonna take the Nailhead in for a complete rebuild Wednesday. It'll take a couple weeks to get it back [dr
    101.8 KB
    106.2 KB
Well, I'm gonna have to find different front wheels.
The two on the front of my build are 14" and I wasn't thinking but, they won't fit over the brake calipers :(
They are 5 on 4.5" bolt pattern.
Old iron, if you wanna keep your 14s, try using some 5/16th spacers and grind the high spots on the calipers down. That's what I had to do to get my 14s to fit over my brake setup.
I'll look at trying that today. I either want to keep the 14's or get 15's like them.
If you're using gm calipers, there's a lot of extra meat on them. What you can also do, which I didn't, is mark the inside of the wheel with a grease pencil and spin it to see just where the caliper is hitting te wheel.
Right on, I'll do that tomorrow. Had to do a repair job on a semi car hauler today.[;)[;) [;)
Great looking build OI.
My build originally planned for a nailhead. I have a 58-364 that needs a complete rebuild.
Those engines are just too pretty to put under a hood. I am saving mine for the time that I build a T-bucket.
Torchie.
Changed the Saginaw out to a super t10 Borg warner with a Hurst shifter
attachment.php
Built the rear seat section
attachment.php
Installed the drivers side inner panel
attachment.php
Installed the passenger side panel
attachment.php
A front view of it
attachment.php
I'll do some more tomorrow [;)
    90.6 KB
    92.8 KB
    87.2 KB
    93.2 KB
    92.5 KB
I finally put the inner structure in so now I'm able to open and close the doors [;) :D
attachment.php
I installed the under dash brake pedal, booster and master cylinder today also.
attachment.php
    96.7 KB
    93.7 KB
Started working on the floor so I made the tranny and drive shaft tunnel first this time
attachment.php
attachment.php
attachment.php
attachment.php
Then I moved on to the rear floorboard and where the rear seat is going to sit
attachment.php
Then the luggage area floor
attachment.php
attachment.php
Won't be able to work on it for a day or two. I have a car hauler trailer coming in tomorrow that need some attention [;) [;) [;)
    85.1 KB
    89.1 KB
    75.9 KB
    86.8 KB
    78 KB
    79.8 KB
    85.8 KB
I made the rest of the floorboards today and will weld them in tomorrow.
Drivers side
attachment.php
Passenger side
attachment.php
attachment.php
So now that the floors are done, I'll remove the engine and take it to the machine shop tomorrow :D
    75 KB
    71.3 KB
    79.3 KB
I thought I would show how I made the tranny and driveshaft tunnel
I set the press brake to make a very shallow bend, held the foot pedal down for continuous run and as the upper die moved up I'd move the plate about 1/4" each time to create this arch. Took about 2 minutes.
attachment.php
This was the results
attachment.php
Tomorrow may just be a cleanup day, we'll see.
    60.6 KB
    76.8 KB
