Complicated Cowl steering...
Well made a little progress...
My cowl steering came from these goals...
1. use the original box cause it was free...
2. keep the box as out of the way as possible
3. i wanted my steering wheel in a certain location (be able to use the big ol wheel)
4. make it cheep
Unfortunately these design criteria didnt lend themselves to an easy solution...
I determined that the location I need to put the box and where the wheel needed to go wouldnt allow me to use steering joints due to the high angels that would have been needed.. I may have been able to go with the extra high angle steering joints but the cheepest I found those were 115 each... and I would have needed 2
So heres where I ended up, and as I review these pictures it occurs to me, you cant really see the box, but it is mounted up against corner of the cowl...
Cost $0.0 I had all the parts laying around from a project I did in school a few years ago...
I built a bunch of structure in there to hold it all up, being that it is a safety critical item I went with double sprockets and 2 #50 roller chains...
I have a little tweaking to do but it works well, next is to build the steering arm and drag link....
