CORPO
Buildin' it his way, one piece at a time...
I also worked on my shifter a bit, I needed a bit more leverage for dissengagaing the ratchet mechanism I made for the gears. The old leaver was only maybe an inch and a half long, so I whittled this out of 3 pieces of steel stacked up
You can see the steps I had to put into it to match with the pivot and the rod that actuates the ratchet
and here is where were heading, I had to reduce the height of my front seat (took out about an inch and a quarter) mounts, I needed more leg clearance for the steering wheel, Life would be much simpler if I got a smaller wheel, but I love the look of the big wheel... Also got my pedals installed, the break pedal needs to be reshaped so that it is more driver friendly, nothing a cutt off wheel and a welder cant fix!
