Hi 36Binder, we share some co-incidents. I had an Uncle Walter, and I have an almost running '36 truck.
Anyhow, I have had to do with Holley 94's, pre and post 1949. They are two barrels and yours is a one barrel. The two barrel carbs from before '49 have the same choke lever as yours does. After '49 the choke was actuated by a wire in a housing, [like has been added to your truck], but the lever on the side of your carb is made to accept a rod with a spring loaded cap. I would guess that your carb is a Holley off of a forties ford six cylinder. That's only a guess.
