We made the little bridge as short and narrow as possible, because we want the smallest tunnel possible. (That foot space deal again.)
Floor pans back in place (everything is temporary, removable and "tacked" together with screws at this point) we made another pan for the tunnel area...
Ran a step bead, chewed a nasty big hole, bent the remains and set it in place...
B-tard hopped in the saddle and started flip-flapping his big feet... hmmm... I thought we could get away with a simple, bent, shallow box, but nooo, no, no, Mister Sasquatch needs every available square inch...
So, we decided to taper the box on two planes, which turned into a five angle, five piece, five hour, fit, fuss and curse session.
Small slippery pieces, big non-magnetic fingers and simple square-headed mistakes, three of my favorite things...
Mistake corrected, fully welded, ground and screw tacked...
One last shot. (That's my fat hand to put things in perspective.) It's 1.75" tall, 7" wide and about 20" long. There isn't another 1/2 inch to take in any direction, so this is as small as it can be!
All those perimeter holes will eventually be plug welded. We haven't removed the panel/tunnel together to see the underside... probably needs a little trimming around the square hole and a stitch weld or 12, we'll see next weekend...
