We played with the bead roller today. We started with a small piece (license plate size: 6" x 12") and quickly realized a couple of issues...
- Issue one: Tiny tight radius corners are difficult and create some gouges when you force the turn.
- Issue two: Patterns should be laid out in the correct orientation... if not, you get a reversed "print". (Oops!)
This is the back side of the small piece...looks OK, but the raised bead is on the other side, along with the die gouges and reverse image.
Back-tracking a little... I figured if we could work a small, tight piece fairly well, a larger piece should be easier... so, we tripled the size, drew the pattern in reverse and enlarged the corner radius to make it more manageable and avoid the gouges...
Not too terribly bad for a pair of professional idiots. We missed the mark here and there, made some crooked straight lines and the result is a bowtie somewhat resembling a baked cookie.
(Practice is clearly required to create a work of art, but we're not concerned with art at this point.)
We turned our attention back to the car and the floor pans. As I mentioned previously, we found a couple well-disguised patches. As you might expect, the patches hid and probably contributed to a larger issue than they were meant to "repair".
We removed the tar-like slather and fiberglass... found a fairly small hole surrounded by perforated thin metal you could use to wrap a potato. We peeled it back to something solid and we now have a hole you could throw a cat through...
The hole (whole) section of the pan will be removed and replaced. The other side is different but similar. The bead roller should serve this repair well.
One last note: The pan is surprisingly complex. It's far from flat and has a depressed "well" of sorts, right where it's rotted away. We're convinced this is the source of the problem as the section has clearly rusted from the inside out...
