No trick, Mac. The front axle is a lift axle and it steers, but cuts a much larger radius than a cement truck with two front steering axles. The rear axle is fixed and also lifts.
The two boxes (indicated below) control drop, lift and airbag pressure... some were manually operated, some were remote/electronic, depending on the customer and his requirements...
The fender height is somewhat deceiving. Our "rule of thumb" was 8" clearance. In the photo above, we obviously had more vertical freedom in the rear and the fender is much higher, probably 11 or 12", again, whatever fit the customer's requirements and available real estate.
Here's another example, built to similar specs. In this case, the fenders are set, more or less, to our 8" standard across the board. Obviously, the lift axles are tucked 8" or less, but it works for the application.
The dry bulk units above were built for Ontario customers. I assume they needed full adjustabililty to meet "weight per axle" requirements for varying roads and varying limits. [S
All this nonsense is counterintuitive by our western standards. I'm sure the examples above scrub tires at an excessive rate with only the wide spread tridem "on the floor". (We're accustomed to B-trains, for the most part, where your head can't fit between two tires.)
Since I'm busy hijacking my own thread... the company I worked for, would build most anything to spec, as long as it was a bulk carrier... crude oil, sour mash, fly ash (hole), flour, peas, fuels of any sort, water vessels to war zones, you name it, within reason...
Anther dry bulk anomaly. We built a small fleet of these things for a customer in Utah. I don't recall what the product was, but it's clear, they needed tip-toe featherweight equipment. Single wheels all around.
One last photo to end this post. (Pay attention, Mac. You're responsible for all this.)
Something we used to call a "Two Way Hauler", now obsolete. They were a "squashed" steel tanker, built like a bloody battleship. They hauled fuel north and returned with lumber on the deck. Tough as nails. I've seen pictures, where one of these trains was recovered from a gorge in BC and soon returned to service. Tough they were, but the nastiest, most difficult animal to build. I don't miss them for a minute.
