I had a few problems to work out but I got it
the red connector pin 9, green/white wire, is positive power out from the computer, I had it wired thinking it was a ground control for the fuel pump relay
so fuel pump wouldn't turn on, I pretty much had 4 hot wires to the relay, lol
I already had a extra ground wire ran, it just wasn't connected to anything yet, I was gonna make it my ground wire for the gauges so not a big deal
and then I had the 12volt wire ran to the fuel level and not the fuel pump
so I fixed that
and then I got fuel pressure and I had some loose fittings, so I had a 60 psi leak, so then I checked all the fittings and two were loose
and then I got the yellow top from my honda pilot and the engine turned over great but still wouldn't hit
so I checked fuel pressure and I had nothing at the rail
ended up being that I hooked the lines up backwards at the fuel rail
after that, it turned over just fine, and hit
it was so nice to finally hear it run
