1937 chevy truck 3/4 ton
Untitled by joa kwin, on Flickr
picked up some new hardware for the spindle to bracket, and my uncle got me 5ea 14mm x 2.0 x 30mm Allen head bolts for the caliper to mount bracket
I picked up the metal to build the bracket as well
my mock up bracket is made out of some pine wood
I ended up making 3 wood mounts overall
make them till I was happy with the fit
I just have to trim the outer edge of the mounts but thats not a big deal
after taking two weeks off, kind of
my uncle hooked it up with some allen head 14mm bolts when I was in Seattle,
i changed out the on/off switch in the mill and got to work
vette brakes on the 37 by joa kwin, on Flickr
vette brakes 2 on the 37 by joa kwin, on Flickr
milled out one 3/8's caliper bracket
my garage is 94 deg right now and i have to get adjusted to it again
i drank a ton of water while in seattle daily
but that weather was 25-35 deg cooler
64974871_432333330680914_8410957648303751168_n by joa kwin, on Flickr
I painted one of the z06 caliper brackets today, gloss black
and so I mounted them suckers up on one wheel
test fit, I have to get some different size lug nuts, so I only have 3 on the wheel right now
and the caliper is hand tight to the adapter bracket.....I need to buy a 14mm allen head tool
twist my arm, I have to go tool shopping tomorrow, lol
What's the idea behind the flat plate upper control arms?
they are different and the stock ones are ugly, and the stock arms needed to be pie cut for ball joint angle
and these flat plate arms dont need it, ball joints still have some travel left in them
I'm just curious why the flat plate ones instead of tubular. Seems like you could get some funny suspension angles?
so far, the ball joints have good angles as the suspension travels
up and down
I haven't done an alignment on the truck yet
65919115_1617263311737540_6510883766028730368_n by joa kwin, on Flickr
last night I stayed up till about 2am working on the left side caliper bracket
took the drop spindle off of the truck and went to town on the bracket,
the bracket I had started to work on, I jacked it up, the bracket lines up on the stock spindle on the money, but it was off a hair on the drop spindle, no idea why but whatever
so I started over on the bracket from scratch, got the metal lined up on my milling machine and went to work,
nice thing about working so late at night is the temp was sitting at about 80 inside my garage
door seal by joa kwin, on Flickr
door seal 1 by joa kwin, on Flickr
door seal 3 by joa kwin, on Flickr
untitled by joa kwin, on Flickr
the replacement window seals for the mini came in on Friday
the last ones I ordered, the box was bent in the middle
65605166_448367382395394_6365354240927334400_n by joa kwin, on Flickr
bent seals dont work to well
so the company shipped me new ones for free, and they covered the four sides of the box in wood, taped the wood to the box, parts made it
the 4 window seals are for the mini, the parts run $100 plus the ride,
so its kind of sucky when parts come in bent in half and are no longer useable right out of the box
s-10 blazer 2 inch drop spindle, dehumped lca, flat plate upper arms, home made caliper bracket, z06 calipers,
home made air bag brackets, SS-7 air bag
worked on this for a little bit today, got the left side mounted
