dowoplover
- Joined
- Feb 12, 2011
- Messages
- 157
do they still make that disc type parking brake that goes on the driveshaft?
Would you happen to have or remember what your original frame length was? I had bought an extra and been trying to verify which year and tonnage it is?
60421761_435394570352147_5899599212730908672_n by joa kwin, on Flickr
im going to fit this tube tomorrow
it will be lined up better then in the picture, but trying to hold it in place and take the pic at the same time wasn't working out to well for me, lol
have to cut it down and notch it and clean up the paint for the area to be welded on
I have to get it done as soon as I get back to the house from the school run
im going to try and go to bed early tonight
so that I can get a cup of coffee in before the school run, so that I can go straight into the garage and get the tube done
and maybe wheel studs
What's the purpose of that tube?
I'm sure it will work fine as is, but I'm curious why you put the airbag mount plates on top of the tube cross-member? If it was underneath, your welds would basically be locating the plate instead of being in constant tension as they are in this configuration. Just my engineering brain, though. No disrespect or negativity intended, just curious.
