Untitled by
joa kwin, on Flickr
Untitled by
joa kwin, on Flickr
Untitled by
joa kwin, on Flickr
Untitled by
joa kwin, on Flickr
Untitled by
joa kwin, on Flickr
shippd the lhd mini up here also now, it needs some body panels changed out and the carb rebuilt
im thinking geo metro 3 cylinder/5 speed manual, to keep it as a cruiser.
3 cylinder makes 15-20hp more, about the same amount of torque, has efi vs carb, and 5 speed vs 4 speed manual, and the drivetrain is around 150-200lbs lighter
my neighbor across the street has a 91 3 banger geo metro, hes going to sell to me for $400..... i plan to get it running to make sure nothing is wrong with it before i start the swap
i started to build a classic mini subframe jig, to build the geo metro subframe off of
but i think it just needs to sections of the frame boxed vs being at a angle and the driveshaft holes in the frame made alittle bigger.... the geo metro automatic driveshafts are shorter and can be used for the mini swap, the minis outer cv joint has the same spline as the geo metros, so i just have to put the mini outer cv onto the automatic cv shaft, as long as i place the engine in the right spot, they will work
and then stick a efi pump into the minis fuel tank and run lines, and turn the geo metros wiring into a standalone set up
