i used like 3 or 4 different size wire wheels,
plus 3 different size wire brushes
the geo metro is a 91, it has 98k miles on it,
the intank fuel pump went out and the car got parked
the valve cover cap was broken, so it leaked oil from that, i got another cap from the junkyard
i ordered a gasket kit for the engine
and trans axle seals
still need to order a new water pump and timing belt kit and clutch kit
clutch is good but the only reason to order a new clutch kit is because its out right now, i have a few weeks before i need to place a order for the other stuff i need
i need to get back on my mini subframe jig
but i need to finish removing the wiring from the car so i can kick that outside and clear up some garage space
Untitled by
joa kwin, on Flickr
had to go buy some long m10x1.25 bolts to put the trans on the engine stand,
i picked up the engine stand used for $20, its a lighter duty stand, but the engine and trans is like 150-160 lbs
the engine uses m10x1.25 for the bell housing
im planning on doing some more cleaning on the trans, prep it for paint
i have some silver paint for the trans
and then i can start on cleaning the engine up,
im thinking of painting the engine a deeper blue color
because the lhd mini will probably be a deeper blue with white roof
