1937 chevy truck 3/4 ton
another project! how did I miss it?
I have some random 37-38 spares around if you need something
the right side I have to build the inner brace and weld in
the left side needs part of the corner box made and also the inner brace
I had to do this on the 41, the best I could do was just plate the bottoms and insides so that the repair is in compression.
you have a back window?
I started to build my back window up, but I think its going to be less work to just replace it
55496020_406254626857445_4374896534299344896_n by joa kwin, on Flickr
cleaned up the valley cover
54514672_306267310046593_6730485671506477056_n by joa kwin, on Flickr
cleaned the valve covers
I have since painted the 2nd cover
55485950_312999799361362_6899397062991806464_n by joa kwin, on Flickr
my $100 ls3 oil pan came in the mail, I already have a new oil pick up o-ring for it, this is going in tomorrow
I have to go to the junkyard to get some stock dowel pins, I had some adjustable ones in the motor, but im giving my manual trans to my brother and dad and they asked for those pins, we hook each other up, my dad is going to use that trans on a 4.3 v6
I still need to buy the dip stick and tube
no back windows, neither glass nor the sheetmetal nor the frames.
I have a perfect hood, and some really nice front fenders, some running boards, probably more if I look.
motor is looking really clean!
56917760_1990842884558305_8930604259683074048_n by joa kwin, on Flickr
installed the iat sensor and 3 bar map sensor onto the intake
progress is slow right now, I got work to do but at the same time im waiting on a few packages, I have 3 boxes that are in no where land
2 of them are with ontrac shipping, late
one has a tool to install the crank balancer pulley, and the other a few tank and filter fittings, I think these two boxes will be in tomorrow morning, because the boxes made it up to phx late Saturday night
and the last one is with usps, it went from Indiana to Florida and thats the last update on it
not sure why it went to Florida because im in Tucson, way out of the route I would think it should go, someone messed up
but it has my fuel injector top hats, ones that box comes in, I can get the rest of my fuel parts onto the motor
I ordered 10 fittings and 40 feet of -6AN push on rubber hose, from jegs
thats going to be for the trans cooler lines and the fuel send and return lines
I still need to figure out what radiator I want for this truck and a trans cooler
its getting close to being able to bring life to the engine inside the frame rails
Sounds like you have it under control.
I've often wondered who thought up the efficiency thing in the new routing plans :confused:[S
[P[P[P
