I stared at that picture for a long time. Then I took off my rose coloured glasses. All I can see is the front wheel doesn't look centred in the wheelwell, but with a straight on camera angle it will be perfect. There's nothing wrong with the car.
Not just the front wheel that isn't centered, the rear is off by 1". I didn't see it until I put the rear wheels on that they are too far back. I've been looking back at earlier mock up pics and it didn't look so bad, but now that full weight is on the suspension, as the leaf springs move up, the diff moves back.
Can't believe this got by me, a major screw up. So at first I was thinking, just drill new pilot holes in the mounts on the diff to move it ahead 1" and shorten the driveshaft. But rather than jump on that, I put the front fenders on (only a few bolts in them at this point) and it's obvious that the fronts are not centered either. Just moving the rearend forward 1" would also be a mistake as the wheelbase is supposed to be 115", not 114" (that's why it's called a 115C model, it refers to the wheelbase). I want to blame my tape measure, but that won't fix it
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. So now the only way I can see to correct it is to move the whole body back on the frame 1". No minor thing now that the interior is finished, body bolts are hidden under carpet and various panels, the shifter will be too close to the dash (bendable) but the hole in the floor will need to be opened up, the brake pedal arm wont fit the hole right, steering shaft needs to be longer and the whole rad/grille shell mount needs to be moved back too. AArrrgghh!!
I can't move the frame mounts or redrill the body mount holes so right now I'm thinking to make 1/4" thick offset plates with studs welded in them to do the job. Fortunately there is enough room between the fan and rad for the move back..... Not looking forward to tearing it apart and lifting the body up at this stage but it can't stay like this.
