thanks fellas!
I was having trouble with my taped on bolts so I chewed out the bedside for the tub, that way I could put a bolt through and get a nut on it. I cleaned it up with a grinder after this picture.
IMG_9134 by Joe Doh, on Flickr
went much better that way, I cut a little more than I needed (pray twice cut once!). what actually happened is I thought the 37-38 fenders had the same mounting pattern because they were on a 41 when I bought it, so I redrilled the fender holes 2" further back. when I was trying to get the running boards cut enough I measured the distance away I was and transferred to to the running board. but since the 37-38 is slightly smaller mounting arc I missed it by just a scant 1/4 inch in the corner. you can see my new hole just forward of the fender, and the small gap in the corner. I will fix both. otherwise looks good enough to me!
IMG_9137-1 by Joe Doh, on Flickr
IMG_9139 by Joe Doh, on Flickr
passenger side tomorrow, then back to the interior. I ordered a fan switch, everyone seems to go with the 185 on 175 off, but the thermostat in these trucks is a 185 stock and most run a 190. so I ordered a 200 on 185 off, I figure it will work better not turning on all the time and cycling the thermostat. if I remember the gauge runs right under 200 in the middle.
