So now that I have time to write, So the drivers side floor pan will be like the image, set inside, so I will have maximum movement for the gas and brake pedal, due to the limited space in the cab, my buddy John suggested it, he also said I could do better when he saw the way the floor pan was crooked, so I'm going to be making a small insert frame for the floor pan to give it more strength and rigidity, it will be made out of 1" wide 1/8" thick flat bar and the floor pan will just sit on it and I'll weld it, it will look awesome from both the inside and outside, I'll keep you posted with pictures, should be done with th all that by this Wednesday I'm hoping lol
, as for the seat I think I'm going to stick with my plan on cutting it in half and re upholsting it, it already has sentimental value, long story short I set it on fire trying to get it out of the 89 chevy, the cab was upside down and I couldn't get to two bolts so I broke out my plasma cutter and cut the first bolt off and it fell inside and caught the seat on fire and I got my pressure washer and put out the fire that was fun, couldn't put it out outside of the cab I had to open one of the doors, took about a minute or so to put it out. , smoke was rolling everywhere, the stoners down the road thought I was hot boxing the cab lol
