Well after a comedy of errors, here's what I have to report:
I ended up taking the front cover off the engine to replace the rope front crank seal with a rubber seal. Got that back on, then my new aluminum thermostat housing wouldn't fit, it was hitting the distributor. So I switched to the old stamped steel one. Then the intake bolts wouldn't fit, so I had to hog out the holes very slightly. Got it all back together and running and the thermostat housing was a geyser.
So last night I re-stabbed the distributor 2 teeth over which allowed me more room for my new aluminum water neck, which with High-tack gasket sealant, arp bolts, and a good gasket solved my issue.
Got the truck running and it sounded good. Then I discovered something else... I'm not getting oil to the driver's side valvetrain. So now I need to solve that issue. The lifters weren't noisy, so hopefully it's something simple.
So now the distributor is back out and valve covers are back off so that I can try to figure out what it's doing and try to re-prime it and get oil to the lifters.
Man, this thing likes to fight me.
This isn't to mentioned whacking myself in the head with the harmonic balancer trying to get it off and hurting my neck and shoulder in the process, plus having to do everything seemingly 3 times. It has been quite the adventure. I hope I can solve the oiling problem easily.
Thank goodness I have a lift, it has made this whole process so much easier.
