1946 Oldsmobile 78 Reserection {my way}
Amputation
Today I finally received the transplant for my seed. It came from old stock warehouse rare find. The fender half was stamped in 52. I use the material from the old Fender and cut out all the corners making a template to show me where I need to trim for the new Fender. Took a lot of thought but I nailed it all my gaps are great everything lines up ********s are perfect enjoy this post
    47.3 KB
    68.2 KB
    34.1 KB
    37.2 KB
    52.5 KB
Body soldet
I finished the fender off with some lead
    52.9 KB
    63.5 KB
    62.8 KB
49 Cad bumper on a 46 olds
I am using a 46 cad bumper but it is to narrow so I butchered another 49 Cad bumper. I cut 1" sections and grafted them in to widen it by 2 inches. Still got to finish the other side.
    88 KB
    53.8 KB
    80.5 KB
    63.3 KB
    103.9 KB
I'm just filling in holes using pieces from the donor to smooth everything out the bumper is now 4 inches wider.
    66 KB
    79.6 KB
    83.7 KB
I am taking more sample pieces from my donor bumper I have welded in the studs for the bumper brackets ground the heads down to clear the new plate. No the new pieces will they didn't know I have to file.
    46 KB
    61.9 KB
    61.8 KB
    42.1 KB
The bumper is now smooth infor in wider all finished next I have to make the bumper brackets fit the front end and build a valance panel.
    64.7 KB
    60.5 KB
    89.1 KB
    75.3 KB
finally I got the bumper mounted. It was kind of tricky finding the right angles with multiple tries I figured out that I would just make a tool which is a t stand and I made a bracket to cradle the bumper and I can move it up or down but I also put it on my two post lift which gave me the right up and down movements I needed in order to get it where I needed it. One of the hardest parts was drilling through the bumper brackets that still is very very hard. Took about 4 hours to finally open it up. No comes the hard part now I have to build the all of the front in to match the bumper but I've been through this same thing I did on the back.
    82.5 KB
    83.8 KB
    67.3 KB
    81.5 KB
    83.5 KB
