1947 ford rat rod build
Ricks Garage
Jul 1, 2011
264
Boynton Beach, FL
"Poncho Deluxe"
1947 Ford Pickup Rat Rod build.
406 Pontiac engine (1973) with 2x4 intake and twin Rochester 4-jets
TH400 with kit and 2500 stall converter.
67 Chevrolet rear end, 3.23 cruising gears.
Front end will be a Ford suicide, Chevelle calipers on mopar rotors.
Oliver 70 grill.
I am construcing a cargo box for the rear from vintage aluminum window shutters.
weld on............[;)
I chopped it 5 inches in front and 4 1/2 in the back.
The "406" is a .030 over 400. ;)
I had been searching for the Oliver grill for over 2 years, that was the first piece for this build. [cl
I have the top about 1/2 welded..
Weld, hammer, weld, hammer, grind...hammer some more..whoops they used lead to fix a portion of the roof, change over to a sanding disk... next comes the doors....
weld on.....[;) and grinding.....
Here it is with its first coat of primer....
5" in the front and 4 1/2" chop in the rear, it has a nice aggressive look.
Next step is to clean up clean up the interior, paint it and start the assembly process.
jump ahead a few months.......
it now rolls. It is wired and plumbed. I am working on the headers and floor.
72 c-10 steering box
67 Caprice 3.23 rear end
ladder bar rear with coilovers
18 gallon fuel tank
chevelle tilt column
sunpro gauges in a IH truck panel (modified)
weld on.............[;)
some more pics when I rolled it out for the first time.
Bob w:
Sorry I missed you question.:rolleyes:
This post is very hard to bring up at times to check.[S
I will send pics tomorrow on the mount that I fabricated.
weld on..........[;)
Bob W, the box mount is hidden behind the radius rod mount.
here are the best images I can get in the garage.
