Hi falconvan, I'm the last guy you should listen to about hydraulic clutches because I have always hated them. Oh, they're alright when they're working, but when they quit, they're a pain in the ----around behind--. The old master cylinders had a residual check valve at their outlet, so if you had that you should be able to keep fluid in the line and slave cylinder. Also, make sure you have a bleed screw at the highest point in the system so the trapped air will work it's way to the bleed screw. The real thorn in my craw about factory hydraulic clutches is 'no real way to bleed them'.
