shakey56
Movin' right along...
Got some stuff done......with help from a couple of friends, Scott and Dean.
Insulated inside of cowl with Peel and Seal. Painted outside of cowl with bedliner.
Modified brake booster (brake pedal) to dash bracket and mounted it to bottom of dash. This bracket is from the donor van.
I am using a column from a 1978 Cordoba. It is the same as a GM column with a wiring harness adapter to fit the Cordoba. I removed the adapter and it fits my harness. The steeering lined up so well that we used the original rag joint. The column drop is an aluminum connecting rod from a hemi race engine. We made a very strong bracket to mount it to the dash. The shift lever on the column was on the wrong (left) side so we cut it off and flipped it over and welded it back on the other (right) side.[
Next I'm gonna take everything out and paint it. I'm also gonna replace the left floor pan and toeboard.
Lynn
Well, I tried to upload photos but it won't let me. It says I'm missing a "security token". Tried to contact the administator but it won't let me do that either! Somebody help???
Lynn
