DJ3100
4 link
Time to make some new parts. But first measure everything again. This time I checked the axle height - it didn't match the front. It is high by 3/4". Can't figure out how I made that mistake. Cut the axle loose from the frame and matched it with the front.
Then I check the frame with a level - It's not close. I had set it up measuring the bottom of the frame to the floor. After chasing that for a while I realized the frame is tapered 3/4" - gets thinner toward the rear. Put the level on the bottom of the frame and put it back where it was.
Leveled everything (left and right) again.
[/URL][/IMG]
[/URL][/IMG]
Measure everything, tack the axle to the frame. Now I'm able to level the lower links and tack them in place.
[/URL][/IMG]
3 days later - really only 1/2 days - and I'm ready to make and modify the parts of the upper links. As I'm doing all this I am remembering how hard it is to cut 3/4" -18 threads in the tube. I really don't want to cut them. On the other hand, 45 degrees is the angle that will provide the best lateral control. We'll see how it goes today.
