soltz
The Rat Captain
[cl NICE [cl
I think you will have better sound with the muffs where you have them. The pipe behind the muff is what tunes the sound waves. It will usually quiet it down a little, and take the ragged sound out, making the exhaust more mellow.
Thanks BAMAMAV and JFG,
The easiest crossover solution would be an H pipe right behind the cross member. Would that be effective?
I could also bring the pipes to the center for an X pipe, but that would move the X a few feet behind the cross member, which is a long way from the engine and add some pretty sharp bends. Is that worth the effort?
John do you flash PCM's? Or do you have someone you trust to get the right?
I put a cross over on my Chevelle and didn't see enough change in it to justify it. It did change the way it sounded a little but that's it.
I've never put another one on. Just my 2 cents worth.
[S[P[P[P[S
I have never been a fan of crossovers, even though they say they work on some engines. I like to watch the pulse of the exhaust on a set of true duals on a cold day. Another thing, if you have a broke ring or bad valve seal, with a true dual system it's easy to tell which side of the engine it's on, the side that smokes. And to me, a car with a crossover just doesn't have as good a sound as true duals without one.
I feel your pain. Really!!
I hate working under something especially on my back.
Is the end in sight?
The cross pipe looks exhausting. I hope it does what you want it to.
That's why I said there are exceptions.......I don't have any experience with the LS motors, so I would also trust JFG455's advice since he has. Looks like it should be free flowing.
