^^^^^X's 2 ^^^^^[cl
[P[P[P
^^^^^X's 2 ^^^^^[cl
[P[P[P
Award winning documentation Dozer. A pleasure to view. Thanks for posting
You're making good headway [cl
Looks good!
If you don't know this already... make sure your welding ground is on the housing/pumpkin or the bracket being welded. (You don't want the current to "hunt" for ground and find it through the bearings!)
. Thanks Doc, oh ya I know about the ground.
Yes that will work very well!!!!!!!!!!!![P
I like my upper bars to run down hill towards the front around 5 to 7 degrees.
The lower bars at 3 degree up in the front creates traction which is better than 3 degrees down.
2 to 3 degrees down would be plenty with the setting of the lower bars where you have them.
