old28
Got to go along with the others, the tank & trunk look right at home. [cl
That front end is a work of art. [
The "up-side-down" front spring setup must be OK, or a pro like you wouldn't be using it, but it messes with my head mechanically speaking. Seems that the weight is moving the spring in the opposite direction of what it was designed for. It will be interesting to see how it goes.The front springs are different and have a bit less arch than the first ones. Made new rear spring mounts. The engine has been raised 2" cuz it was too close to the ground. The trans crossmember is fabbed and tacked in place. The trans and rear end line up good so there should be no driveshaft problems.
The large aluminum tank you can see in the background was a Craigslist find. Looks too big however.
I like the vintage oval tank too, corpo. Just don't know if it will fit this build.
The body is channeled 4" in front and 2" in back for a little forward tilt. Made body mounts. Cut out the firewall for bell housing clearance.
This is getting to be hard work for an old man.
Nice kitty cat.I bought this Jag hood ornament off of Craigslist for 20 bucks today. It'll be the only classy part on the car.
Yes Skip, the frame moves away from the spring/axle when it hits a bump. That's why the spring is restacked.
More details on the pitman arm redesign would be greatly appreciated, if you please good Sir. I have an Econoline column that I would like to use on my next project. I assume the reclocking is due to moving it from the front to behind the axle. Correct?A couple questions to answer: The steering box is an Econoline. I've used one before. Only problem is the pitman arm has to be reclocked. Tonight I merged the Plymouth pitman arm that came with the tube axle with the top part of the Econoline pitman arm. The Econoline arm is too short resulting in very slow steering. All welds are reinforced.
I plan on using 16" steel wheels off an early Mopar. The rears are left over from the '40 Plymouth pickup I had. Have to find a pair for the front. The roadster needs tall tires because the frame is so low. Tires will be skinny.
