MercuryMac
Builder Junky!
I mocked up the steering column setup and it passed. Some figuring out of the 'brushes' that will contact the brass rings happened.
Here is the steering wheel with some epoxy putty applied. The whitish place on the radius is the piece I never found. The hub in the middle is three loose pieces now, but jammed together. I will patch it up with body filler later. The body filler is a way nicer to work with than the epoxy putty, but the putty makes a better wheel in the end.
