More bolts in place again today. The first picture is a tin addition to the inside of the lower fender where it meets the running board apron. I'm not sure how I'm going to hook the apron to the new strip, though.
The second picture is the headlight and it's mounting pedestal bolted up, [quite a feat, as the good fenders had holes drilled for horizontal pedestals mounting and I needed vertical bolt holes.]
    3.3 MB
    3.7 MB
Your tinkering is getting more done then anything I'm doing these days. Keep plugging away at it. It gives me something to read. (y)
When the cold front came in this morning, ruining our nice Chinook, there was quite a wind storm. So I wasn't done shaving when the power went out. Boy, does it ever get dark in the bathroom in a hurry. Some of you guys should invent light that dissipates gently.
Anyhow, I imagined that a tree had fallen across the power line somewhere. I tried to think of what I could do today. Boy, these days you can't do much without electricity.
I went to town and got some lunch and a pair of coveralls. That's work related, ---- isn't it?
I've been thinking along those same lines. How dependent we are on electricity. No heat, no light, no water. Looking into getting a generator. Yes, your day was work related.
The cold front is rolling in for us last night/today. Yesterday we had a lot of wind and a bit of snow. Hard to tell how much, 1-2" on the front side of the house and 4-5" on the back side due to the wind.
Near us last night a main gas line was accidentally hit and a lot of people had no gas for several hours. Luckily we weren't impacted, but it gets you thinking. Going without gas is probably a lot easier than going without power, though.
I got to worrying about my front signal lights. They have to look old and reasonably authentic [on a vehicle that didn't have any], and the inspector who allows me to get my registration will want them to work. Plus, I probably have to have park lights in the front signals too. So for a while now I've been tinkering around with a pair of oldies. Pic one, is the base plate rebuilt to accept an 1157 12 volt bulb. This is no easy task, as the 'one filament' socket that was on there would not accept the twin filament bulb even with quite a bit of modification, [hours and hours of modification]. The 1157 bulb is almost too big to fit inside the glass, also.
Pic two is the base plate bolted to the fender. And, pic three is the glass and the tin shroud mounted.
Pic four is the steering column back in for some measuring. I've even started to look for the bracket that I made a long time ago.
    3 MB
    3.2 MB
    2.8 MB
    2.5 MB
Mac, did you get those lights to work for you? I have found several different LED light types that are really small and really bright for signal lights online. Easily adaptable into small fixtures. They are polarity sensitive. Some are used without sockets too.
https://www.amazon.com/gp/product/B01NAHYUBD?ie=UTF8&th=1
Thanks Guys. I had a pair of LEDs here that I'm going to put in the back of my '55 Merc truck. They just twist in to the socket like an 1157 bulb would, but although they're smaller around, they are longer so they didn't work for me. I didn't know about those little wee ones, though.
Today, I mounted the bracket on the firewall that will accept my shortened steering column. There are times when I can see the advantages of putting a flathead six in an old hotrod, as that left hand head of a V-8 is in the road of everything.
pic 1 is test fitting the bracket.
pic 2 is the U-joint just missing the valve cover.
pic 3 is the bracket bolted in there and workable.
    2.8 MB
    3.6 MB
    3.8 MB
I think I would reroute those plug wires, if they are as close as they appear.
I had a steering knuckle snag a plug wire once as I was rolling down the highway. It was blowing in the breeze more then i thought it was. The knuckle wrapped the plug wire around the steering column until it made it really hard to make a curve on the highway. I overpowered the steering, but immediately developed a misfire. I thought something was really messed up. When I opened the hood and found the plug wire wrapped around the column and was pulled off the plug it really was a relief (the wire didn't fare very well). I limped into the next town and had to but a set of plug wires. That time the wires were more secured. Somethings you don't easily forget.
Thanks for the concern, Gene. I went back and studied the picture again and realized that the perspective is somewhat throwing you off. The U-joint is further away and lower down than it appears is the picture. The tin shroud around the wires is not just a round pipe, it tapers thinner and droops down quite a bit. The U-joint may be close to the shroud but not really to the wires.
Today, I did something, [away too late in the operation], and I knew better also. I sat in the seat and made Vruumm, Vruumm noises. That's almost a law around here. While you are acting slightly childlike, you should check your pedal comfort and your steering wheel height. I chose to lower my steering wheel 4" and make the truck more drivable.
Pic one is what the end of the steering column looked like before. That's the horn relay gizmo, [the brass rings].
Pic two is the column shortened 4", the shaft bushing slid four inches, and a new snap-ring groove built in.
    1.2 MB
    2.5 MB
Yes Bob, we should keep comfort in mind when we're building. I feel a little sheepish that I didn't do this a while back.
More shortening today. I cut the steering shaft off, then bored a slanty hole in it, [pic one] to fish the horn wire up through.
[Pic two] is the wire brought up through the hole and the insulated brass ring installed. The wire is jambed under the brass ring and in contact.
    2.2 MB
    2 MB
Guys, you'll remember those two brass rings on the bottom end of the steering shaft, well, here's the electrical contact gizmo that will reach though the mounting bracket and run against those rings. The heads of the tiny bolts run on top of the rings. I had cut two holes in the mounting bracket for the plastic gizmo to fit through. [pic one].
[pic two] is the plastic gizmo in place with electrical 'spade' connectors also in place.
    1.8 MB
    3.8 MB
Ya know how sometimes you plan and plan things out and still when you get near the end, you find an almost insurmountable problem. Well, I had that today. As I was putting the U-joint in on the end of the steering shaft, I realized the set-screw to hold it on was inside the sleeve of the mounting bracket. I could see the nut in there if I held the flashlight just right and I could touch it with a small thin screw driver. After some head scratching, I thought to drill a hole in the bottom of the bracket-sleeve right behind the tin plate that is welded on the bottom of the sleeve [that will be flush with the toeboard. I was able to work through that hole. Pic one, is the steering column in and done.
[pic two] is more clearance of the U-joint to the valve cover, [about an inch more].
And I sat in the seat and turned the steering wheel. I feels good, although I may have trouble getting my leg up high enough to step on the clutch when the door is closed. My knees are a long way from my feet.
    3.4 MB
    3.2 MB
Smallfoot, there are adjustable stoppers on both pedals but I can't remember if the rods to the master cylinders are adjustable, [probably, though]. I'll look into it while it's easy.
[pic one] is the permanent toe board anchoring side piece that now has been fixed up and changed. I had to move the pedals a wee bit so the dimmer switch was too close to the depressed clutch pedal, so I moved the switch down quite a ways.
[pic two] is the toe board in place. There were many, many trial fits and trims. So then I added the emergency brake handle. Bssssst, bad move. The handle will have to be rebuilt, because it won't work that way for a number of reasons.
    3.6 MB
    3.4 MB
It turns out that I could not figure out a way to make that emergency brake handle work in this truck. I had done quite a bit of imagineering, but no. So I went to my stash of brake handles that would be 'era correct' or at least 'era pretty good', and selected an older looking one with no ratcheting mechanism. More imagineering. Now I'm building the internal semi-circle with the teeth in it.
