smallfoot
Science says carbon under pressure produces diamonds....[P
Someone has to show the up and comers what is wrong and how to fix their own stuff[P[P[P
Looks like you weren't blowing the soot out of it often enough [ddd[ddd[ddd
I've been learning stuff about Pertronics electronic ignition. This ignition module needs 12 volts to run and if you have a resistor in the system between the key switch and the coil you won't get any spark. So you have to remember where you put that dang resistor and get it out of the system. Which I have now done. The truck started right up nicely. The oil pressure idiot light did not go out as I hoped it would. By then supper was called and responded to, and the 4-H kids started flocking in. Maybe tomorrow, I'll remove the sender and mount a real gauge. I've checked the wire and the light and they seem fine.
Torchie, You should be alright with a Y-block in a boat because there will be lots of room to work on the distributor. On a '56 Ford you have to lean in over the fender, around the hood hinge, under the back of the low opening hood, and work in the partial darkness around the distributor cap that can't be moved much because of the firewall right there. Y-blocks rule!!!! [except for points setting].
On the partsmen never hearing the term Idiot line; my tongue was in my cheek. I was just seeing if you guys were paying attention. Keep up the good work.
