8literbeater
Difference in height? As long as you keep those angles equal and opposite, you'll be fine.
Opposite, meaning one is angled up, and the other is angled down. Both can be the same way, after all, that's how a double cardan CV joint works. Usually it isn't used on driveshafts (except for the double cardan CV), because then the pinion would have to be pointed way up, and the don't get oil to the front pinion bearings that way. Also, when suspension travels, one angle would get smaller, and the other would get bigger. So when you put the pinion parallel with the transmission output shaft, the angles stay equal (or close) throughout suspension travel.Yes, the way you have it setup is normal, the angles must match up. there is another school of thought, that the angles can by opposite, which theoretically works exactly the same, but I hear people saying it simply does not work.
Either way, this looks like it'll be a great buildup, and a good reliable drive afterwards.
Connecting all the electrical and electronic stuff would scare the **** out of me though.
Lots of cars have had batteries mounted under the seats. It isn't that much of a problem really. It would probably keep your battery cables shorter too.Here was a thought that didn't last long for placement of the batteries. I was thinking a hinged floor and passenger seat to access but that sounded like a lot of work to be inconvenienced when needing access to a battery
True story. A door or removable panel makes for fairly easy access. If jumpers are the concern, they can be mounted in a convenient location in the engine compartment near the starter. If the exhaust isn't "right there" it is good use of otherwise wasted space.Lots of cars have had batteries mounted under the seats. It isn't that much of a problem really. It would probably keep your battery cables shorter too.
Have you considered making or obtaining a metal valve cover, rather than spacing the turbo away from the plastic one?
-Chaz
