Willowbilly3
A *real* tin magnet
Well, not really a build, Henry already built it. I'm just fixing 75 years of wear and tear right now. You've probably alread seen the work I started on the door. Here I am tackling the door opening and it's a mess too. First is getting out the torched off door hinge stubs.
I purposed to get rid of a couple square feet of smurfyness every time I work on it.
Next is get the lead out, over 1/2" thick in places.
And where I quit for the day. I did get the twisted up lower r/h door post straightened but mostly just dismantling. Next is weld a brace across the bottom to keep it together so I can work on the broken out top corners.
