tagged up!
I ordered mounts but they havent come. I did as much as I could without them. I found some dimensions online and the mounts I am using (70 camaro) should be as tall as the s10 mounts, so I did mock up with a couple S10 bushings.
my kingdom for another inch! I decided to lower the cab another inch, my reasoning is that s10 front suspension does some weird stuff at full droop, the wheels pull back in the wheelarches and the toe goes all wonky, I like setting the truck up to lay on the running boards (well, very close to it) while the frame is still a little off the ground and that keeps the suspension from needing expensive mods like tube arms and tie rod notches. I trimmed out the frame carefully, and the piece I cut out will flip over and weld back in. this lets the part of the rocker that hit the frame go by slightly.
this is as low as I can go without cutting the back of the cab.
you can see where the running board will be, it is about 6 1/4 tall, leaving 7 3/4 ground clearance before I install the 3" lowering springs.
I bolted the s10 body mount in to make templates for mounts.
front mounts made!
more tomorrow. I realized that the tag office put the wrong VIN on the paperwork, I will run in the morning and correct it. All the front end components came in yesterday, I bought the problem solver MOOG stuff for everything. If I can get the rear mounts built and everything tacked in when the camaro mounts show up, I can pull the cab to do the frame cleanup and engine move. on locating the cab, I set the centerline of the front wheels at 31 inches to the door edge. I will tack everything in and put the front clip on to make certain the wheels are centered. This was the measurement I took off the parts 41, so I think it is right, but I will still double check.
front mounts made!
