Chop looks great Cantwell! Almost wish I had cut another inch or two. [dr As you know I chopped mine the same way. Everything just fell into place as well, just a little more welding. The only problem I had was I had to adjust the front of the door window frames a little so the glass will be able to ride to the top without binding. I did this by putting a relief cut in the back side bottom of the front post and taking a wrench and putting a slight twist to line it up and then re-welding. As far as my windshield, my opening is perfect on both sides and flat top to bottom and side to side. Again, looks good keep the pics coming. [cl
