Old Iron
Looks good
I need to get started on doing the same to my 33.
I was getting a bad case of depression due to lack of cruisin time caused by the cold temps lately. Decided it was time to get the interior of cab finished.
I got about 1/3 of the peel and seal in yesterday. Plan is to install peel and seal, a layer of foil insulation and then carpet and head liner. Then a small hot rod heater from Jegs. Then I'll be warm and toasty.
I ordered all the stuff to rebuild the doors and install the glass from Dodge Central of Michigan. Kinda pricey, $260, but it's all made to fit and they had everything.
FYI....I used one roll of peel and stick from Lowes and one roll of Home Depots version to start with and to compare the two. IMHO, Home depots stuff is a little thicker, sticks a little better, finish is a little smoother and is $1.50 a roll cheaper. Plus I hate I Lowes here, so I'm going with Home Depot.
I absolutely love this truck [dr [cl
Looks good
That's looking good, pops!
We have different definitions of pricy! I find if I'm undertaking a rod project and it's less than $300 I'm doing good. I guess stuff costs us more up here, though.
Looking good my friend. Keep it up and you will be in good shape in no time. She sure has come a long way since she left the place. Kudos to ya brother. [cl
The one thing I overlooked is the inside door panels. I did the door skins, but the inside panels are huge drums that seem to produce a lot of noise.
Looking good as always.
i do too
what a kick butt ride
roger does great work
Looking great POPS.[cl
I hear you about the heat deal! If I didn't put some insulation and heat in my cars, I could only drive a couple of months a year without fighting fogged up windows. That truck is turning out super nice!
http://www.ebay.com/itm/281879167082?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
So I wanted to be able to lock the doors on my truck and I found these on ebay. Just what I wanted but they are both for the right side door.
My question for all you talented and all knowing is can I take one apart and
make it work for the left side? If so how do they come apart?
Don't know why a stock old dodge has a keyed lock assembly on the ride side door only? Makes no sense to me.
Torchie, I guess that makes some sense, getting killed might leave a mark.
05snopro440; I looked at the '34 ford locking handles, I thought they looked too fancy for my old hoopty.
When I tried just turning one handle over it only turned up and turned the wrong direction to operate the door mechanism and they only turned a quarter turn against a stop. I took one apart and with a dremel tool I removed the lug for the stop. Works great now.
I love it when a plan comes together.[cl[cl
I'd like to see someone tr to exit on the pass side from a car nowadays, with the small cockpits, floor shift and consoles [ddd
