'48 Olds
Got some more done today. Started on the rear section today. I thought I'd need to split the roof lengthwise,
but after I cut it and placed it, it'll work to just bend the posts. Sweet!
Anyhoo.... I decided the best place to cut the roof would be between the two main bows.
I added some bracing before the cut line.
attachment.php
attachment.php
Lined up the C-posts and it leaves a 5-1/4" gap.
attachment.php
It also brought the back end out to something more manageable.
attachment.php
I used the top of the rear door to align the two sections.
There is a slight curve that needs to match up.
attachment.php
    151.5 KB
    113.4 KB
    89 KB
    89.7 KB
    36 KB
Another 1/8" needed to be cut from the C-post for the door frame to line up. And the roof.
attachment.php
Next, the C-post was about a 1/2" off on each side. So to get the post to line up,
I cut the lower post at the belt line. The top part just bowed out.
attachment.php
Adjusted post compared o the door.
attachment.php
Just a pic with the top off. What a mess.
attachment.php
Lines up well.
attachment.php
    42.8 KB
    42.2 KB
    161.6 KB
    44.8 KB
    50.5 KB
The posts line up nicely.
attachment.php
Tacked in place. I may still need to tweak the curve of the door frame.
attachment.php
And that wraps it up for today.
    99.8 KB
    53.2 KB
I see much welding, hammering and grinding in your future..[P
So which of your photochop options did you decide to go with ?
Lookin' good, keep it comin.
I'm going to try to keep it a 4door. 4"chop, 4" section (whatever the metal allows).
If the doors/door glass got to be a problem, then I was going to go for option 2 - panel. If that failed - convertible.
I liked the panel a lot (A LOT!), but decided to stick with doors in the end because of functionality.
I didn't get to spend but a few hours in the garage today. Worked on filling the gap. Managed one side, but the other, I got a bend off so need to go back and make another piece. I'll need to relief cut the rear section to match roof sections - I'm planning that cut at the top of the edge filler pieces. (Drip edge to be added later.)
attachment.php
Looks to be a good fit.
attachment.php
And something I pulled out of the scrap bin I didn't know I had!
attachment.php
    110 KB
    64.3 KB
    56.4 KB
Made a new piece and got the other side tacked together (got called away).
That's probably gonna be about it for a few days.
attachment.php
Didn't notice until I quit working, the garage was kinda cold.
attachment.php
    43.5 KB
    44.4 KB
