Got a couple hours to work on it tonight so I thought I would post up what I did. Got the radiator from my bro so I washed it out real good then started mocking it in position to drill holes and bolt it up. He took the radiator and cut the tanks off and shortened it up then re-tiged the tanks on and tiged up some side flanges to bolt it up, Thanks Rich!! I had one small issue with the bracket that was fixed easily with a cuttoff wheel and a welder. I got it all mocked up clamped it and drilled the mounting holes. Bolted it in and tweaked it around so it was square. I had a brand new set of radiator hoses that were for the stock Jeep Commando motor that is in it and it just so happens that the Mitsubishi Lancer Evo 8 radiator outlets were in almost the exact same spots!! Filled it up and no leaks so I will run it when I get it to that point to see if it has any leaks in the system. I then proceeded to work on the shock setup. Turns out its a bit of a pain in my you know what to fit a 36" shock under the hood of a lowered Jeep. Back is fine since I have all the room to go up. Front however I really dont want to drill a hole in the hood. What do you guys think? Should I stick them under the hood or pop them out? I have a couple shots of a steel tube to let you know how long they will be and how high they would sit standing straight up. Onto the pics!
Here is the tube steel which is how long the shock will be when attached standing up like this. If you read above, give me your idea lol.
