I spent all day yesterday on the front end, replacing the shock bushings, leveling the springs, bleeding the brakes (they didnt bleed, master wasnt pumping fluid).
found out why the lines were dry
replaced the master and it was dry too.
went to cardboard freight today for a pressure bleeder. I always get the crappy cashier who wont honor coupons, so I paid full pop retail, oh well. I did pick up a couple moving blankets to cover the seat and carpet while I finish stuff. I was getting a lot of air bubbles, the rear lines didnt bleed at all for a while and then when they finally did (only way it pulled fluid was with the cap on) it was rust colored for a while.
pedal feels good, fixed the lean (cut a 1/8th coil off the passenger side, no judgements please, the s10 lean is a real thing) replaced the upper shock mounts, actually they werent bad just had a couple pieces flake off. I would drive it but the gallon I put in there has evaporated.
level finally
went and got some gas. the filler was overflowing when I put the first gallon in and the internet said the evap valve was plugged. I pulled it loose and blew through it and viola, fixed. I went for a very dark cruise haha.
notice that it is facing the opposite way, this is the first time I didnt have to grunt my fat ass to push spin the truck around in the driveway. quite a moment. I let it get warm and gave it the beans, it runs like a swiss watch. I must have been quite a sight, no door, no bed, no lights except runners, wild eyed.
when I got back I had enough euphoria left to flip the carcoal canister. funny story, since I swapped frames from an 03 to an 84, obviously it didnt have the mounting holes for the charcoal canister, so I held it where the lines looked right and drilled holes. then I looked at putting the bed on and realized it stuck up way to far and the bed would need a brace cut and some more work on lowering the canister as much as I could. well, when I was looking at the cleaning instructions for the evap valve, I noticed I put the thing on upside down.
so I drilled a couple new holes, wow look at all the room now
must be something in the water, get out your fishing rods, I am a doom bass. :lol:
might get the bed on tomorrow, and the drivers door, although I like having the door off to do all the trim and wiring so maybe not yet. I looked pretty seriously at wiring the headlights while the wheels were off, but I need the three prong harnesses.
