4bbl spacers
23crate
Moderator
Staff member
Moderator
Sep 26, 2014
1,491
new zealand
hey All,
heres a fun game ive tried, with surprising results..
ever since ive owned my Lark, its been plagued with a miss around 26-34mph - town speed - (unrelated to other carb issues)
under the carb sits a 1" high - 4 port spacer. for comparison ive included an open plenum spacer
now the 3rd is the one ive found interesting. clearly designed to aid flow, without filling a hole ,, as the open spacer does.
ive had a number of thinks about 3rd pic spacer,, knowing i can buy a 4 barrel spacer cheap, i dragged out my die grinder and burr,
while the Stude doesnt have the Edelbrock Performer (4th pic) stock 4bbl manifold is split the same.
i spent some time carefully 'flowing' the spacer to replicate the flowed version , trimming out about 1/2" leaving the center section = split manifold;
Stude 8's are not well known for ease of breathing,,
after an careful hour , and polishing with a purple strip it disc , re-assembly the round town miss had gone completely, and the car seems to run much more smoothly between -50-60mph .. and it maybe feels a bit quicker
this article i found interesting ,,,
https://www.hotrod.com/how-to/pit-stop-carburetor-spacers-affect-performance/
was worth the time and a good result .... smiles all round really
Apologies if was a bit over zealous in describing my doings,
    112.8 KB
    54.3 KB
    7.3 KB
    103.1 KB
OI in the link, theres a suggestion that tapered bore allowed the air fuel mix to slow, and curve into the manifold runners smoothly , instead of dumping straight into the plenum, and having to think about which manifold runner...
thanks Gene, is good to get a positive result for sure ,, better if someone here benefits too :cool:
i build my spacers too, i haven't made one like that yet but get a lot of enjoyment in the machining process. the last one i made was a 2" 2 oval holes to keep the intake 2 plane. couldn't tell you if it is a good one or not but it sure does help with clearance problems on the engine. as others said, would have never thought about the spacer unless there was a leak.
