Dirtyrat
Got Fins?
Well, it was a really long day, got my scrap run done, about 500lbs of scrap steel with the old tank being the bulk of that.
Also got the truck over to the fill station for 10 gallons (And those *******s charged me about double the going rate for propane right now, so I'll be getting it through my work next time hopefully) One major leak on the fill line, the guy putting the lines on forgot to tighten the fill line at the tank... oh yea that would be me... And a small leak at the fuel distribution block area mainly because its going into aluminum and I have a hard time cranking down on lines in aluminum... So with those sorted out we filled all the fluids, and gave it a good purge to get the air out of the tank, and tried a couple times to start the motor, but no dice, no cranking just yet, need to do a little trouble shooting tomorrow.
Pump runs, and I manually tested the starter & solenoid and it will crank the motor.
So I have a few things to look into tomorrow, as I know I am missing some of the wiring that I previously removed/disconnected as it was mainly for lighting and dash stuff...
Some of the fuses were checked, now I'm going to get further on to the relay for the starter and see if its wiring or the ECM that is not satisfied to fire the relay...
