MercuryMac
Builder Junky!
Very nice tin work. I'm pretty happy with it too, Dutch.
sooo... finally got some work done on this project. First time I build a fender this big ... now the other side in half the hrs
Nice job!!!!
On the bed rails, did you use tubing on the edge or did you roll it. If you rolled it how did you go about doing it?
Another question; I never did any bodywork on a truck like this and since this was an incomplete rotten pos when I started, I have no clue if , or how the running boards were bolted to the fenders? Is it a wise thing to do? or will body flex wreck things? Use rubber mounts between fender and board?
looks amazing! is the scoop in the board to allow you to stand up closer to the bed? because I just stand on the board.
the boards do bolt to the running boards, the original has 3 bolts in an "L", two low one higher. the apron bolts too, just one bolt at the back. I can try and get a picture for you today. like you suspect its not for board strength but to keep the fenders from wagging around.
You'll have to contact admin to do editing on older posts.
