Finally... an update!
I forgot all about this thread....was posting updates to the weekend thread. Here is some of the progress I've made since finishing the book and handing the manuscript over for editing.
After mounting the Camaro front sub-frame, I rebuilt the front suspension completely. I discovered some problems with the 302 I was going to use, so found a roller-cam 5.0 to replace it. It's used, but hopefully will live long enough to allow me some time to save some funds for a rebuild. It has stainless shorty headers, an old Edelbrock Performer 289 intake manifold, and a Holley 600.
I took an old aluminum scoop I had and turned it into a carb hat that I hooked 4" tubing and a filter to for a poor man's cold air setup. I bought a HEI distributor, E3 plugs, and MSD wires. The front pulleys and brackets were all for a serpentine setup, so I got a Gilmer-style belt and pulley set and a set of brackets for the alternator that I had to modify and mount in "alternate" locations to accept the Ford alternator and allow for enough contact area on all three pulleys for the belt.
I bolted a'84 AOD to the 5.0. I'll probably use an old Mustang floor shifter and a cheap GPS speedo to make things easy. A Marston bracket kit will allow the TV cable to hook up to the Holley without problems (I hope).
I mounted the front fenders and hood to the front of the body and made brackets to attach the fenders to the Camaro sub-frame, along with a modified stock radiator support to provide the hood latch and a place to attach the 31" aluminum radiator.
I bought and mounted a universal heater and need to figure out ducting and such for defrosters and floor vents.
I found Camaro front rotors with studs on a 4.5 bolt circle, installing them with new bearings and races so I can have wheels on all for corners with the same bolt pattern.
I sold the old Cragars I had with the tires on them for enough to buy a set of 235/60/15 tires and a few more parts, like lug nuts, dust covers, radiator hoses and clamps, etc. I have a set of turbine-spoke aluminum wheels from an old Lincoln Town Car that I'm going to use, deciding not the radius the rear wheelwells after all. I bought new rotors and pads for the 8.8 in the rear, as well.
I need to stop again for awhile, to make trophies, design and hang posters, make sure everything is ready for the Steel Stampede show in July. I hope to have the car done by Spring, at least to where it will run and move. I'll need to find someone to align the front end and set up the TV cable on the AOD.
That's about all for now. I'll try to update this thread when I get more done.
