animal
I finally got a day to work on the car, in amongst all the home remodeling...
I was going to test fit the junky old trunk lid I found, but when I was getting ready to bolt it up, I found the right hinge was wonky. I took it off, found the stop was worn off, and the pivot pin was badly worn. I took it apart with the help of my grinder, repaired the hinge pin with a grade 8 bolt with a short shoulder for the pivot area. I ground the head down to fit where it had to go, then put the nut on the other end and cut it down to where it will clear everything and tacked it in place. I welded a small piece of 3/8" square stock on for the stop, put everything back together. I bolted it to the car, found out the stop needed just a little "adjustment". Took care of that with the grinder, took the hinge back off and set out to reinstall that %#@* spring. After a period of time where I tried not to hurt myself or anything else while clamping the hinge in the vise, I got fed up and drilled some holes in my outside work table, bolted the hinge to it, and used a big pry bar and some wood blocks to get the spring stretched and in place. Jeez, what a hassle!
